Setting reminders
Setting reminders
Hi. I am a long time user of EPIM and am very happy with it as it does all I require. I am wanting to install a new copy in a friends tablet but I cannot find where I can set up a reminder for selected birthdays like I could in my earlier version. I dont require all birthdays to have a reminder only selective ones. Thanks for a well thought out App.
- Has thanked: 2 times
- Been thanked: 60 times
Re: Setting reminders
Simply go in your selected contact. At the upper right of the page, set your birthday date and reminder.
NormTheStorm
Win10 Home Version 22H2 (OS Build 19045.4170) 64-bit, 8 GB RAM, EPIM Pro Life 11.8.4
I must have a different version. I go to contacts and press the pencil symbol (upper right)which gives me a list which includes additional fields. Click birthday and I get a list of additional fields like anniversary job title etc. but nothing as shown above
I see ! You have EssentialPIM for Android 4.1.5
If I may suggest, you should post in the Android section in this case. I can't help as I do not use it ! Sorry.
NormTheStorm
lemuzz, this feature is available in Android EPIM 4.2 Beta 2. Let me know if you wish to try it out before the final release version, will forward you the instructions.
Thank you Yes I would like to try it. Will you please forward instructions. Thanks. Lemuzzadmin wrote:lemuzz, this feature is available in Android EPIM 4.2 Beta 2. Let me know if you wish to try it out before the final release version, will forward you the instructions.
Good! Please check your PM.
Hi. I have installed EssentialPIM 4.2 Beta 2. which I believe is the Test Version.
When loading birthdays in the "Contacts " field, I cannot find where to set a reminder for selected dates. I realise there is a global reminder setting but in many cases I dont want to be notified for every entry, just those I need to know.
Thanks, noted, will probably add this functionality in the nearest future.
