EssentialPIM 7.2 release is here!
Dear EssentialPIM users,
it is a pleasure to announce EssentialPIM 7.2 for Windows and EssentialPIM 4.5 for Android.
Windows version can be downloaded here and Android version here.
Full list of changes in both versions.
- Has thanked: 20 times
- Been thanked: 165 times
Re: EssentialPIM 7.2 release is here!
i just updated my buisness network editions.
at the first try i got errors when i switched the module from calender to notes.
I can not remember the exact error message, but i clicked the *send* button (14.12.2016 ~00:20)
It was a kind of tableview error
occured only when connected to a database. Occured on server and client.
Cause i couldn't solve it (even stopped firebird server and reinstalled) i switched back to 7.13 on my server / client machines.
any idea?
best regards
any idea?
best regards
*including RC`s
*including RC`s
I'd wager you probably received this error as well: At the moment the only work arounds I've found is using only the SYSDBA account to login as it's the only account that works or reverting to 7.13 (Note the database used by 7.2 is not compatible. so you will need to restore the backup of the converted database to revert back to 7.13 until this error is fixed.)Texter wrote:i just updated my buisness network editions.
any idea?
best regards
As a side note you could* fairly easily fix the error yourself running the SQL command "GRANT ALL ON PARAM2VIEW TO <USERNAME>;" However I think for compatibility reasons it would be best not to do this and instead use one of the above options until the developers officially fix the issue.
Yes @MetalDrop ! exactly !
yes, not compatible.
No, SYSDBA isn't usefull, because we are (also) using private notes.
I'm just waiting for a solution. 7.13 runs very well
*including RC`s
*including RC`s
- Has thanked: 1 time
- Been thanked: 2 times
Re: EssentialPIM 7.2 release is not working!
Very sorry that vers. 7.2 is not working!!
Reinstalled vers. 7.13 without a problem using actual database.
I'm just waiting now for a solution. 7.13 runs very well.
1. PC Notebook (HP EliteBook 2540p, Upgrade Intel Core i7 CPU, WIN 10pro x64, 8GB RAM, 512 GB SSD)
2. Dell Inspiron 14, WIN 10pro x64
3. Lenovo Tablet (Android Vers 4.4.2)
4. LINUX & WIN PCs
5. GE / EN
6. EPIM Pro, Vers 8.1
7. UMIDIGI Android 8.1
4. LINUX & WIN PCs
5. GE / EN
- Has thanked: 43 times
- Been thanked: 29 times
Подтверждаю, - 7.2 не работает должным образом. Синхронизация выдает ошибкуm.advisor@web.de wrote:Very sorry that vers. 7.2 is not working!!
Sorry, Volodymyr, what have you stated?
4. LINUX & WIN PCs
5. GE / EN
4. LINUX & WIN PCs
5. GE / EN
Good afternoon!
Almost everything in version 7.2 EssentialPIM Pro works OK.
There is one major exception that happened to me three times today. When replying to an email that I have received and select part of the text in the received email, press the control key and try to drag and drop the selected text into my reply (all in the same window), I get an access violation message from Windows. When dismissing the Windows error message, EssentialPIM crashes. I have no problem restarting the programme in the same Windows session (no reboot necessary). Needless to say, when I restart it, the email reply I was working on was gone. Because I use EssentialPIM to access my McGill account and to reply to my students' queries, this is quite inconvenient. Should I downgrade to version 7.13?
My system runs Windows version 7 Professional 64 bit on a system with an Intel chip, ATI Radeon video card, MS Comfort mouse 3000 and 4 gig of memory. Both mouse and keyboard are connected via USB ports.
When you have fixed this bug, I would appreciate an email notifying me.
Thanks,
Grant
Thanks,
Grant
программа вылетает с ошибкой при попытке вставить / перетащить в сообщение html с картинкой.
В версиях 7,13 и ниже все нормально работало, зачем все ломать ?
да и вообще это нормально, если программа вылетает при обработке тегов в тексте ?
(win 10 x64)
(win 10 x64)
On advice from Anton I deinstalled now vers. 7.13, downloaded vers. 7.2 (pro) and installed that version.
Everything works fine now! Thanks!
Rgds Hans
Rgds Hans
4. LINUX & WIN PCs
5. GE / EN
4. LINUX & WIN PCs
5. GE / EN
Since I installed V7.21 I get an error message conc.: Socket error # 11001 Host not found.
Didn't change account settings or other settings.
Reinstalled freh d/l V7.21 without any result.
Any idea?
jannuh
Any idea?
jannuh
Hello, I just went to install 7.22 and got this error:
Affordable Business Solutions LLC
- Has thanked: 1412 times
Please check out the following topic:
viewtopic.php?f=2&t=18856&p=82203
Most probably that was a temporary glitch. It is working now.JurGraf wrote:Hi,
I can't get new release from page
http://www.essentialpim.com/get-epim
EPIM.jpg.
Regards,
JurGraf
