EssentialPIM 3.2 Release Candidate 2 (Public)
Hello everyone,
here goes Release Candidate 2. We fixed most of issues raised in the forum within yesterday and earlier.
Downloads:
EPIM Free Desktop: http://www.essentialpim.com/download/be ... lPIM32.exe
EPIM Pro Desktop: http://www.essentialpim.com/download/be ... MPro32.exe
EPIM Free Portable: http://www.essentialpim.com/download/be ... Port32.zip
EPIM Pro Portable: http://www.essentialpim.com/download/be ... Port32.zip
Fixed:
  • "Dissapearing tasks" - all data is now shown
    class tnttabcontrol not found in Notes
    Repeating task deleting
    Search in Notes
    Notes HTML export
    Transparency color in Notes
    Recurring event synchronization with Google calendar
    Data convertion in Schedule
nick2112
Re: EssentialPIM 3.2 Release Candidate 2 (Public)
Post by nick2112 »
sorry if this question seems a little lame, but I just downloaded the Pro Portable version (I have the paid version on my U3 drive) and am trying to get the software to show up in the U3 smart programs launch pad. Please could you tell me how I can do this?
Many thanks for your time and help, and Happy Thanks Giving to you all.
Nick
ivg
Post by ivg »
Hi!
epim portable 3.2 rc2
so far I have not tested much of it but::
Custom Colors Have finally appeared and function well in Notes!!
Also transparent color swatch works well now!!! -
Now bad things:
If you excuse me but How UGLY the new look of THE TABS is!!!!
Please change it back!!! (or make a setting to use old slyle tabs)
For my personal use - I won't switch to 3.2 unless tabs get a proper look.. (I can tell you they don't fit well at all in epim - and i am a graphic desiner by the way///)
petrsimanek
Has thanked: 19 times
Been thanked: 11 times
Post by petrsimanek »
By the way I am a graphic desiner too - and I think that the tabs are not bad. No need to change them :)
Petr Simanek
EPIM user since April 2006, Beta Team member, always uses the latest stable and beta/RC version under Windows 10 Pro
nick2112 wrote:Hi,
Nick
you will need to install U3 version in order for it to appear in U3 menu. But currently there is no U3 version for this RC. WIll appear later.
bluedigit
Post by bluedigit »
Garbage characters
in the win2008 r2
let's translator of Chinese Simplified better!
ivg
Post by ivg »
to petrsimanek
Most likely you're not using win xp classic style - thats where the new tabs look explicitly out of place.
Oversaturated border color of the tabs is not consistent with the rest of the interface (toolbar borders etc) let alone the border has a gap ( is not connected with the frame it belongs too) which only add to the overly amateurish look.
plus I noticed other misfortunes with the new tabs.. like a gost borders, double borders and so on// look ugly indeed (pls do not get offended - just a few of constructive points)
so pls make our tabs look consistent or switch back old style tabs
thanks
Has thanked: 1616 times
Been thanked: 1133 times
bluedigit wrote:Garbage characters
bluedigit, what language is it - Chinese simplified ot traditional? Why garbage? What should be instead? Are you using your own language file or the one that currently comes with EPIM? Thanks.
Can4e3
Been thanked: 4 times
Post by Can4e3 »
bug with tabs. in my case - garbage diagonal line:
BTW - its part of screen "EPIM Today"
petrsimanek
It's interesting, it probably depends on the gradient fill of inactive tabs. But cannot confirm, on my Vista SP1 notebook the tabs are displayed OK.
Petr Simanek
Thanks, can confirm the issue with the diagonal line on Vista. Will fix.
bluedigit
Post by bluedigit »
in the english
10452=Underline
10456=Text Background Color
10469=Search and Replace
10475=Strike Out
10476=Insert Date and Time
display ok
but in the Chinese Simplified display Garbage characters
10452=下划线
10456=文本背景色
10469=查找与替换
10475=删除线
10476=插入日期和时间
os: win xp /win 2008 /win 2008 r2
Chinese_Simpl.lng
(35.17 KiB) Downloaded 403 times
Can4e3
Post by Can4e3 »
bluedigit, its not a bug of this RC, all questions about lang-garbage you can post in relevant topic or topic and contact with translators of <Simplified Chinese> Language file.
its simple to check this bug - just remove garbage characters from lang file and restart epim. If garbage characters - still displaying on program window - its may be bug of RC, and if all Ok - see upper strings of my post and contact with translators.
bluedigit
Post by bluedigit »
Can4e3 wrote:bluedigit, its not a bug of this RC, all questions about lang-garbage you can post in relevant topic or topic and contact with translators of <Simplified Chinese> Language file.
this questions is bug , if language characters is english display ok,when in Simplified Chinese only "10452 10456 10469 10475 10476 "characters will display garbage characters, the Language file is ok.
bluedigit, thanks but couldn't reproduce the problem with garbage chars using the latest language file you posted in the forum. All's being shown correctly on our side.
