Excluding Inauguration Day, January 20th every four years and Election Day, Tuesday on or after November 2 which will need to be put in manually.
These are USA holidays. Feel free to add and improve. If I missed any please let me know and I will fix.
There are government and other important dates alos. Up to the year 2014.
United States Government Holidays
- us_holidays.zip
- (752 Bytes) Downloaded 1822 times
An "F" in english? Bobby you speak english.
I guess I really screwed up this time. I tried to import my iCal to WebCalendar and got some kind of error. It was kind of late, and I think I should have quit a lot earlier. I didn't save it as a epim first. Now when I try to import it into Epim, I get a fatal error.frankokc wrote:I'll have to take a look at yours. I tried one, too, but it didn't export to iCal.
FrankOKC
- EpimMemError.gif (8.05 KiB) Viewed 18518 times
I might have missled you. I designed a similar calendar and tried to import it to WebCalendar, but it didn't work. I think I figured it out, though. I don't think we can use two years (2005-2006).moloko wrote:I just tried the file and it works fine importing the ics file. I am not getting that error.
FrankOKC
.ics file placement
Please excuse my ignorance, as I am new to PIM. I don't know where to download the .ics file to. Nor do I know how to integrate the (us.holiday) data into my epim. Suggestions? Thanx
Hi Reggie,
you can download the files by a click on "download" and "iCal calendars". There you can download the iCal calendars. If you don't belong to the beta tester team you cannot use the iCal calendars because they are supported in the beta version of EPIM. Otherwise you have to wait for the final version 1.7.
