Request for new iCal support: UID
Postby johnson29630 » Thu May 11, 2006 2:05 pm
I'm trying to syncronize data from a project schedule database using the iCal import into EsentialPIM. If the UID was supported, I could synchronize EPIM with by database:
> If the UID matches a record already in EPIM, update it with any changes from the iCal record.
> If the UID does not match an existing EPIM record, import it as a new record.
> A UID should also be included in the iCal export from EsentialPIM
johnson29630
Has thanked: 0 time
Have thanks: 0 time
Postby admin » Mon May 22, 2006 9:13 am
We'll have something similar introduced in EPIM 1.8.
Has thanked: 109 times
Have thanks: 39 times
Where is this feature?
Postby salcedok » Tue Apr 24, 2007 6:29 pm
I have version 1.95 Pro and this feature is not there. I had a similar need and found a workaround by exporting project to EXCEL and writing a macro to convert the EXCEL to an ICS file but I have nothing that checks for duplicate To Do items. Is there a feature to ask for confirmation prior to importing a duplicate item?
salcedok
Has thanked: 0 time
Have thanks: 0 time
Postby admin » Wed Apr 25, 2007 11:08 am
This feature will be introduced in EPIM 2.0. Thanks.
Return to iCal Calendars
Who is online
Users browsing this forum: No registered users and 1 guest
