hi max,
i sent the latest full logfile as decided on february 9th to You. I am still waitung for answer now.
Best regards
phillip
Geburtstage fehlen teilweise
- Has thanked: 1412 times
Re: Geburtstage fehlen teilweise
Got it and replied. I think the problem is that your sync with your phone's contacts and not with EPIM's ones.
i sync with my phone's contacts only, that is correct. I will not use EPIM's ones, but i would like to see the birthdays in my phone's contacts. Should i use two different contact lists to see the birthdays? You can't possibly mean that!
Phone contacts work differently for each phone manufacturer. Theoretically you should be able to see the Birthday field in your contacts but whether that's true depends on your phone's account and we cannot influence it. If you would like to get the best integration possible, we recommend to use EPIM contacts.
