For better overview, sometimes it would be fine to 'switch of' some categories / terms. but it is a long way to go to this command in the menue.
A Shortcut- / Filter-Option for categpries in the menue-line
could help to make the Workflow more comfortable.
Other Shortcuts could be for example:
- Number of lines in monthview,
- Number of days in weekview.
These are just my favorite-commands...
Editable Shortcuts could maybe help for also other commands to make them more comfortable to use.
Best Regards and thanks for your good work!
Harald
Calendar View: quick access to personally important commands
Re: Calendar View: quick access to personally important commands
thank you for the suggestion. By the way, you can already now edit the shortcuts in Options (though the shortcuts you mentioned are not there)
Sounds great! - have installed new version right now (7.23), but cannot find our, where i can "edit shortcuts in Options"...
Maybe you can give me a little tipp?
Best regards
Harald
Best regards
Harald
Please use Tools-> Options-> Shortcuts menu
oh yes - this "shortcuts" i know, and use them!
Sorry for my bad explanation: what i did mean, where (alterable) "icons" / "buttons" in the menue-line (like in mail-view: "delete", "filter" / in calendar-view: "go to", "today"...)
