Heb epim Pro geïnstalleerd op m'n android toestel. Het laden van de agenda verliep prima.
Helaas synchroniseert de agenda en taken niet met de cloud.
Wat kan ik hieraan doen?
Synchronisatie tussen Google kalender en epim Pro werkt niet
Re: Synchronisatie tussen Google kalender en epim Pro werkt niet
Please specify which cloud you mean. Google services?
It doesnt sync with my desktop calander.
Txs for reply.
Txs for reply.
Is there an error message? Thanks!
Unfortunately it's impossible to help without knowing all the details. I can only suggest you to have a look the help file here: http://www.essentialpim.com/help/index. ... oid_os.htm and probably here: http://www.essentialpim.com/help/troubleshooting2.htm. Will it help?
Thanks, though I only want to sync with my calander on my phone and the Google account via the internet.
By setting up the account, my first synchronisatie, it works.
Making new appointments, either in Pim, or in Google are not synced anymore.
Regards
Regards
Ah I see now, thanks for the explanation. Please try to disable Google Calendar sync (Settings->Calendar->Google Calendar Sync, select the Do not sync with Google option). After that restart the app and enable synchronization again. Will it start working again?
