Bug when using "Repeat To Do"?
Postby lk » Fri Feb 03, 2012 5:30 pm
Hello!
There seems to be a problem with the "Repeat To Do" funtion - if I change the repeat interval from its default, the changed number (of days, months, years) won't be remembered.
Steps to reproduce this issue:
  • Create a new "To Do" item
  • Give it a subject and check "Repeat To Do"
  • Change the "Repeat every" field to something different than the default value of 1 (e.g. 6). Click on "Ok".
  • Double-click on the just created To Do: The "Repeat every" field shows a value of 1, no matter which value you have put into the field in step 3.
If you change "Day(s)" to "Month(s)" in step 3 above, save this value and reopen the To Do item afterwards, the repeat values is set to "Day 3 of every 1 months" (!) Is there something wrong with this (very handy) Repeating To Do function?
And the caption of the buttons "EPIM Today" and "To Do" in the left column is truncated by about half of a letter width:
(EPIM Pro 4.53 on a fully patched Windows XP SP 3 32 Bit, German version)
lk
Has thanked: 0 time
Have thanks: 0 time
Re: Bug when using "Repeat To Do"?
Postby lk » Sun Feb 05, 2012 8:24 am
Is noone able to reproduce this behavoiur? I just tried it with a fresh EPIM Pro installation on a virtual machine and the problem is 100% reproducible, even with a new database. Can anyone who uses this feature confirm this?
lk
Has thanked: 0 time
Have thanks: 0 time
Postby admin » Sun Feb 05, 2012 2:14 pm
Yes, we were able to reproduce the issue. Will fix it in the next minor version. Thanks for letting us know about it!
Has thanked: 109 times
Have thanks: 39 times
Postby lk » Sun Feb 05, 2012 3:24 pm
admin wrote:Yes, we were able to reproduce the issue. Will fix it in the next minor version. Thanks for letting us know about it!
Glad to read this. Thank you.
lk
Has thanked: 0 time
Have thanks: 0 time
Postby lk » Thu Feb 09, 2012 3:49 pm
Just want to report that v4.54 seems to have fixed both issues! Thank you!
lk
Has thanked: 0 time
Have thanks: 0 time
Postby lk » Thu Mar 08, 2012 4:19 pm
Unfortunately, there are still some bugs when using "Repeat To Do". Steps to reproduce them:
  • Create a new To Do entry and give it a subject
  • Check "Start time"
  • Check "Repeat To Do"
  • Click on "Advanced", choose "Weekly", "Regenerate new to do 6 week(s) after the completion date" and uncheck any checked weekday.
    The radio button "Regenerate" is now unchecked, which is at least confusing - why does the behaviour of the "To Do" change if I uncheck the weekday option?
  • Choose "Regenerate..." again and click "Ok" twice - the To Do item will be created.
  • Reopen this freshly created To Do and change its start time to something different, click "Ok" and reopen it again.
    The "Regenerate..." option is again lost and "Recur every 1 week(s)" is checked.
It seems that under some circumstances the "Repeat To Do" options are reset to their defaults.
(EPIM Pro 4.54 on Windows XP SP3)
lk
lk
Has thanked: 0 time
Have thanks: 0 time
Postby admin » Fri Mar 09, 2012 9:38 am
Confirm both of the problems, will be fixed in the next version. Thanks.
Postby hannibal_barca_1974 » Fri Mar 09, 2012 11:12 pm
The way you have explained your problems ilk makes this thread a superb future reference. Thanks.
hannibal_barca_1974
Has thanked: 5 times
Have thanks: 4 times
Postby lk » Tue Jun 26, 2012 8:02 pm
admin wrote:Confirm both of the problems, will be fixed in the next version. Thanks.
Unfortunately this bug is still present in v5.0 RC2!
lk
Has thanked: 0 time
Have thanks: 0 time
Postby admin » Tue Jun 26, 2012 8:16 pm
It turned out these were not bugs but intentional behavior.
1-st issue. Weekdays belong to the "Recur every" section and when you either check or uncheck days, the focus is being transferred to this section.
2-nd issue. As the start date changes so does the recur pattern, which is now set to repeat every 1 week (if you do not go to the Advanced dialog).
Return to Support
Who is online
Users browsing this forum: No registered users and 2 guests
