I cannot get rid of this modern color scheme (blue background) in Contacts in v. 7.2:
It was ok in 7.13.
-- M.
Contacts color scheme makes titles illegible
Re: Contacts color scheme makes titles illegible
Mel, what's your Windows version?
Thanks, will try to fix in the next minor version.
- PeCe
- Has thanked: 101 times
- Been thanked: 329 times
Wow, it seems to me that finally (with 7.21) the display problem, as Mel also posted, has been solved.
That makes me very happy. This means I can use the contacts page without irritating me on the bad displayed information.
Maybe I even will use that as the default now and switch back from the [all fields] tab.
We specifically addressed the issue for the 7.21 version If there is anything else we can do, please let us know.
