password for syncing google contacts
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
A long time ago I have set up a synchronization from EPIM Desktop to Google, syncing only the contacts.
I now want to check & maybe change the settings of this synchroniszation, but when I choose to edit this synchronization a popup appears asking me for a pasword. I can't recollect or find this password, can't even remember entering a password when setting up this synchronization.
What can I do?
- Is there any way to retrieve the password?
- Should I delete this synchronization in EPIM Desktop and set up a new one like it? Or will this not work & will I still need the original password to create a new synchronization?
Thanks in advance.
Kind regards.
Re: password for syncing google contacts
you can delete the synchronization and create a new one in EPIM.
