Bugs with synchronization for Android app
Georgo2010
Has thanked: 32 times
Been thanked: 54 times
Post by Georgo2010 »
Hi guys,
let me tell you some bugs:
1/ Dysfunctional synchronization of contacts, synchronized notes are displayed in one line!
2/ Why after synchronize are created in EssentialPIM (for PC) a new "system" tabs, although they don´t exist in app for Andorid?
Suggestion:
* Try to fix it, please :(
* If is connected to wi-fi network, please highlight text in brackets (1 step of instruction during PC Sync) with name of wi-fi network (eg. by yellow color) :wink:
Jiri Humplik
http://www.epimcz.wbs.cz
Has thanked: 1616 times
Been thanked: 1135 times
Re: Bugs for Android app
1. This will probably change in the future. Thanks for your note about current situation
2. Fixed
3. You get updates automatically from the Google Play Store, not sure if we should send out a newsletter about that
App issues:
1. Cannot do that unfortunately as the app is called EssentialPIM (no space)
2. Yes, can do that
3. Will do, thanks for the suggestion
4. Please mention specifically which of the strings aren’t implemented. Will check text overflow issue. We include all the latest Android strings into EssentialPIM language file
5. Sorry I don’t understand what you mean, please rephrase the first part. No crash for us in Passwords. If there’s a crash on your device, please send the log file out to Google and we’ll retrieve it from there.
6. Fixed in 1.3.6 version, please update
7. Crash shouldn’t happen in the first place. If it happens, please send out the log file to Google from within the crash window
8. Noted
9. What are the names of such tabs? Also, once you delete them, they’re gone
10. Noted, thanks
11. Yes, widgets are in the plans
Georgo2010
admin wrote:2. Yes, can do that
App issues (for Android):
ad 2.
Suggestion: After first run (or any time later after press menu button next to About window) show pop-up window "What is new?" in specific version and history changes.
I prepared a sample window :idea:
aEPIM - Whats new.png (23.19 KiB) Viewed 6259 times
Jiri Humplik
Georgo2010
Re: Bugs with synchronization for Android app
admin wrote:3. Will do, thanks for the suggestion
ad 3.
Suggestion/Issue: What about add copyright to About window and decrease font size for web link, email (overflow!). Thank you for little improve this window.
I prepared simple window how could be it more professional :idea:
aEPIM - About window.png (56.6 KiB) Viewed 6259 times
Jiri Humplik
Thanks for the samples, will surely take them into consideration.
Georgo2010
admin wrote:4. Please mention specifically which of the strings aren’t implemented. Will check text overflow issue. We include all the latest Android strings into EssentialPIM language file
ad 4.
Bug: Why are not implemented some of czech string from latest language file which I post it? Why some of these overflow (eg. "PC sync" --> "Synchron..") or stay untranslated (eg. item System default language)? Where can I download and compare/try to fix actual language file for Android?
I corrected all the strings which overflow (it was very difficult for me to fix because the english strings also overflow :roll: ), and better renamed. Where can I upload czech language files for Android?
rp_no_records
rp_no_records
aEPIM - rp_no_records.png (7.8 KiB) Viewed 6256 times
Translated string "ep_system_default" for system language without change in menu, but after select show it correctly!
aEPIM - select language.png (49.32 KiB) Viewed 6256 times
You can´t use long form for month because strings overflow! I try to fix it for czech language
aEPIM - Repeat pattern.png (94.9 KiB) Viewed 6256 times
String ac_app_name is defined too short, so I tried to fix it (to english short form) for czech translation
aEPIM - Main menu.png (62.58 KiB) Viewed 6256 times
Jiri Humplik
Georgo2010
admin wrote:5. Sorry I don’t understand what you mean, please rephrase the first part. No crash for us in Passwords. If there’s a crash on your device, please send the log file out to Google and we’ll retrieve it from there.
ad 5.
Bugs: Why I don´t see password hit in Password module? Isn´t covered by button "Done" (instead of putting down) or showing text "Wrong password"? After enter right password app (1.3.3/1.3.5) crash, although you´ll write "Fixed crash in Passwords" in Google store (https://play.google.com/store/apps/deta ... sentialpim). Please improve this section :!:
Crash app after enter wrong master password in Password module was probably fixed in the latest version (1.3.5+), thank you. However, when I enter an incorrect password, I´ll don´t see defined text for help (password hint).
aEPIM - master password.png (16.07 KiB) Viewed 6256 times
Jiri Humplik
Georgo2010
Hi guys (from development),
Here I have prepared repair of the Czech translation (mainly overflow strings and minor modifications,line feed - eg. you can see to string "ac_wifi_yes" on my little improvement --> can you please write it on a new line instead of show in brackets?) for android which you can. Next time I create for it new post (or you can give me detailed instructions).
I hope I answered everything. Have a nice day. :)
czech for android.zip
czech language from EPIM 1.3.5
(4.6 KiB) Downloaded 259 times
Jiri Humplik
Thanks, will try to fix all these inconsistencies in the next version.
Georgo2010
admin wrote:3. You get updates automatically from the Google Play Store, not sure if we should send out a newsletter about that
Not all have check automatic update or are off-line. I think it would be good idea inform current registered users by email (in newsletter for PC version) about news in app for smartphone too - user can decide. I guarantee you this is just way for a growing interest about download and increase in popularity (score in e-store) :idea:
Jiri Humplik
Will think about it. Thanks!
