I just downloaded EPIM to a Lenovo yoga 910, win 10 64bits. I install the program. I open the program. I click File, Sync, Add sync, google, and the program gives error message "Access violation at 0x77D132A6 (tried to write to 0x000A0FFC), program terminated." This happens every time - I cannot get past this. Any ideas, other than uninstall the program????? Not much good to me this way.
Elliott
EPIM crashes on sync attempt
Re: EPIM crashes on sync attempt
please try to uninstall and install the program again. This is not a known error, maybe related to a particular device.
Any ideas? I uninstalled, reinstalled, with same results. What's up guys???
I would suggest to try the same database on another computer. This way you would know if the problem is related to your particular machine.
