Problema settaggio pagina iniziale
Gigatrek
Post by Gigatrek »
Da qualche versione, non riesco piu' ad aprire automaticamente EssentialPIM all'avvio di Windows sulla pagina del calendario.
Nelle impostazioni, apri con ultima scheda aperta non funziona e nell'altra opzione esiste solo apri su rubrica.
Era così comodo
Grazie
Re: Problema settaggio pagina iniziale
what is the version you are using? (version number and Pro/Free?)
Can you please post a couple of screenshots demonstrating the problem?
Gigatrek
Post by Gigatrek »
Thank you Max for your frast answer.
I'm using a free version number 7.1.
I make some screen-shhot to explain the problem.
Only rubrica shows that in menu there is only Rubrica as like option.
My set up is my actually configuration.
Before close shows how is my module before i close application, if as module you mean " Rubrica", Calendario", " Note" etc.
The last picture, After restart, shows as like my Epim restart after i close it or after i turn on the computer.
I'd like that the first page that appares when i start my PC will be Calendar.
Is a free version point? Must i buy professional version? In older version 5.0 it works so.
If i must buy professional version, updates is for one year?
Thank you
amaseb
Been thanked: 6 times
Post by amaseb »
Hi everyone,
I've tried to reproduce it on my EPIM (Free 7.11 portable, Win 10).
If I change any setting in the option menù, the "Apply" button is activated, but if I change the setting from start EPIM from "contacts module" to "last opened module" the "apply" button is inactive and the only option is to push "OK" or "Cancel" buttons.
I've made this test many times with the same result. My database is opened according to the settings of the modules.
To Gigatrek:
Have you already tried to reinstall the program, deleting the old windows registry entries?
Regards..
Gigatrek,
please go to Tools-> Options-> Modules and make sure if all modules are turned on. If that does not help, reinstall EPIM.
Gigatrek
Post by Gigatrek »
Thank you Max,
i'm waiting an email notice, but i read that after the first it's not expected.
I see in options modules and i've got only contacts and trash. i dont'have calendar.
The same in start with, the drop down menu has got only Contacts.
Some release ago (4), here, there was calendar too.
i try to re-install Epim but it's the same.
Now i've got three possibility,
1 install EPIM4 and disable update check.
2 Install a new release free, if it is released.
3 Install a professional version if you ensure me that it will go correctly.
Best regards
Gigatrek
Post by Gigatrek »
I try to install EPIM 7.12, but the broblem is the same.
Regards
Please remember path to your database file, then exit EPIM, search your computer for EPIM.ini files and delete all the files. Restart EPIM- that will reset all the settings. Use File-> Open to open the file.
Gigatrek
Post by Gigatrek »
Thank-you MAX.
I solved my problem in this way.
I close EPIM, i delete Epim.ini and an old professional EPIM Folder that i try to install.
When i start EPIM i update it to 7.13 release and now all work properly.
Good day
Silvio
