Importazione password
pillo68
Post by pillo68 »
Buongiorno.
Cambiando telefono molto spesso ho sempre importato le mie password da un file .csv che mi sono sempre salvato.
Oggi ho cambiato telefono ma non riesce più ad importarmi le password.
Con la voce "importa da sd card" mi trova il solito file che installo nella directory principale, me lo riconosce, mi chiede se sono sicuro di importarlo, e poi mi da sempre in risposta la voce:
"ERRORI IN IMPORTAZIONE"
:cry:
Come mai ?
Grazie a chi mi può aiutare.
Paolo
i've always changed my phone and imported my password importing a file .csv that I saved before
Today I changed my phone but I can't import my password
In the menu "Import from SD card" the programme find my .csv file, it ask me if I'm sure to import it and than it reply me:
"ERROR IN IMPORTING"
Somebody can help me ?
Paolo
Re: Importazione password
Please mention the app's version number. And, if possible, the app version number you exported the password entries into the CSV file from.
pillo68
Post by pillo68 »
Version 4.2.6 but I don't know the previous one.
Is it a password protected CSV file? If yes, please make sure you specify the correct password.
I could upload an older version of Android EPIM for you, the one you exported the CSV file from (so that we could check if you're able to import the file back specifically into that version) but I need to know at least the approximate version number..
