Imorter des anciens fichiers EPIM
Moderator: daprod
mitche
Post by mitche »
Bonjour, j'ai essential PIMPRO, mais il m'est impossible d'importer des anciens fichiers, quand je veux le faire, les fichiers n'apparaissent dans le dossier d'importation!! est ce qu'il y a une solution à ce problème??
Merci d'avance
Re: Imorter des anciens fichiers EPIM
please post screenshots of what's not working. You can use File-> Open-> menu and select *.epim file to open it.
mitche
Re: Importer des anciens fichiers EPIM
Post by mitche »
Thank's for answering but that's what i do but it doesn't work, you can see , on the screen shot the message ...
Excuse my english :oops:
That's what the answer after "importing" new files
If you are using File-> Open menu and it gives this error- something is wrong with your database. Please have a look at backup files you might have (by default EPIM makes backups into folder directory). If nothing helps, send your database (or the link to it) to ma@essentialpim... with a link to this topic.
mitche
Post by mitche »
i have create my own files backup, the database et the backup files are not in the same folder...
Is that answer ???
You can also search your computer for *.epim files or *.epim.bak files.
If you do not find anything, send us your database as indicated in my previous post.
mitche
Post by mitche »
But i'ts my choice to have separate folders, one for database et one for backups.. :oops:
Should i put them in the same folder??? :?:
thank's :D
mitche wrote:But i'ts my choice to have separate folders, one for database et one for backups.. :oops:
thank's :D
It is completely up to you.
I am just responding to your request of not a valid database- means you can find and open/use backup file.
mitche
Post by mitche »
Ok, than you for our aswers...
Have a good day
jean michel
