Android version
FutureDominium
Android version
Post by FutureDominium » Fri Apr 13, 2012 4:47 pm
EssentialPIM is actually the best PIM ever. I removed lot of other tools (email clients, outliner and so on) moving all my infos to EPIM. But... I miss some features. One of these features is the possibility to run EPIM on my Android Device. I was using Evernote that works great on Android. I used it to record voice notes, to take photos and so on, and after the sync i had all those infos in my desktop and notebook. I would like ot do the same using EPIM.
Is it possible for you to create an android version of the EPIM?
Thank you.
Has thanked: 296 times
Been thanked: 235 times
Re: Android version
Post by Max » Mon Apr 16, 2012 9:10 am
yes, we are working on an Android version, it should be released within months.
viewtopic.php?f=1&t=13483
hannibal_barca_1974
Has thanked: 6 times
Been thanked: 4 times
Re: Android version
Post by hannibal_barca_1974 » Mon Apr 16, 2012 8:31 pm
An Android version is a great idea. :)
Xa4
Re: Android version
Post by Xa4 » Tue Apr 17, 2012 9:13 am
Android version will be a great thing. Now I have problems to look at/update my calendar, contacts, ... lets say "on the road" I want to use this asap.
Will it be available free for pro users?
Looking forward to this!
Xa4
Epim pro lifetime license user
gameplay
Re: Android version
Post by gameplay » Fri Apr 20, 2012 12:33 am
Waiting for the android version too. Hope it does not take to many month.
Georgo2010
Has thanked: 28 times
Been thanked: 47 times
Re: Android version
Post by Georgo2010 » Thu Apr 26, 2012 10:30 pm
+1
It sounds great - a lite version as Android application (calendar, tasks, contacts, notes), yes please.
Jiri Humplik
main czech and slovak translator
external support page: http://www.epimcz.wbs.cz
MS Windows 10 Home 64-bit: EssentialPIM Pro Portable 7.22 (@150 dpi)
Android 5.1.1: EssentialPIM 4.6
hannibal_barca_1974
Re: Android version
Post by hannibal_barca_1974 » Thu Apr 26, 2012 11:46 pm
Georgo2010 wrote:+1
Your ideas for the lite version (calendar, tasks, contacts, notes) would be my preference too! :D
Has thanked: 463 times
Been thanked: 263 times
Re: Android version
Post by admin » Fri Apr 27, 2012 11:03 am
People, have you been trying to search for EssentialPIM in Google Play Store lately? If not, I encourage you to do that :)
You will find an app that allows synchronization of Android Calendar and Contacts (built-in ones for the moment) along with To Dos and Passwords (our own creation) with EssentialPIM. To Dos and Passwords are two fully working modules that closely correlate with EssentialPIM’s philosophy and should be a joy to use for all EPIM’s users.
Later on we plan to add the Notes module (and synchronization with it) and after that Calendar and Contacts will follow. Stay tuned and please report your thoughts and suggestions about current version of the Android application.
Oh, and one more thing. EssentialPIM for Android will work with EssentialPIM 5.0 version only. You can download the first beta versions (prepare to find some very interesting features in the new version) from here:
Desktop: http://www.essentialpim.com/download/be ... MPro50.exe
Portable: http://www.essentialpim.com/download/be ... Port50.zip
Important! Please backup your current EPIM database file first (although, there’s an automatic backup but Beta is Beta, right) before opening it with the Beta version.
Georgo2010
Re: Android version
Post by Georgo2010 » Fri Apr 27, 2012 11:55 am
admin wrote:People, have you been trying to search for EssentialPIM in Google Play Store lately? If not, I encourage you to do that :)
I am disappointed. :? What's so great about this version EPIM 5.0B1?
- unable to open database from version 4.5
- very unstable
Thank you I don ´t want this!
known problem from previous versions after open (new) database
EPIM 5B1 - 01.png (8.52 KiB) Viewed 3832 times
Jiri Humplik
Re: Android version
Post by admin » Fri Apr 27, 2012 12:01 pm
What does the error message say? And if you could copy your database from 4.54 into a new file, then open it with 4.54, delete all the sensitive data and then forward to us, we will then try to fix the issue you're having.
Georgo2010
Re: Android version
Post by Georgo2010 » Fri Apr 27, 2012 12:23 pm
admin wrote:What does the error message say? And if you could copy your database from 4.54 into a new file, then open it with 4.54, delete all the sensitive data and then forward to us, we will then try to fix the issue you're having.
OK, I´m sending you right now backup of my database (without sensitive data) with error report to "errors".
EPIM 5B1 - 02.png (11.77 KiB) Viewed 3829 times
Jiri Humplik
Who is online
Users browsing this forum: No registered users and 2 guests
