Ability to tap and call phone numbers from any field
Ram8
Has thanked: 21 times
Been thanked: 10 times
Post by Ram8 »
The native phone app contact file [and most of EPIMs competitors] allows the user to tap a phone number from any field, such as the Notes field, which opens the phone dialer and inserts the number. I have hundreds of contacts with comments and phone numbers in the Notes field that I do not want to enter as a seperate contact. When traveling it is especially important to be able to "tap and dial" from this field. Right now I am having to try and memorize the number or write it down, then switch over to the native phone app and dial it - extreemly cumbersome. Adding this feature will be an important step towards full integration with the native phone app.
running EPIM Pro 5.6.2 on Android 9 and EPIM Pro 8.53.1 on Windows 10
Re: Ability to tap and call phone numbers from any field
Thanks very much for the suggestion, will add this feature into one of the coming versions.
Ram8
Post by Ram8 »
Great! much appreciated.
Ram8
Post by Ram8 »
Hello Admin, any updates for adding this feature?
This will be included in the 4.6 version.
Ram8
Post by Ram8 »
Thank Admin. Look forward to this feature.
Ram8
Post by Ram8 »
This feature is now working on my phone. Works Great!
