Are you able to confirm that the Export Selected Notes function does not work on the FREE VERSION?
Am using the EssentialPIM Portable 4.23
What I did is as below:
- Select a Note
- Then click File -> Export -> Notes -> Choose ( HTML, RTF or TXT )
- This bring up the Notes to be exported window, then I choose Selected, Include Header and then click -> OK
Program says Export complete. Exported: 1 note(s). However, when I opened the exported HTM or TXT file, all it contains is the name of the note plus a Last modified text.
If I choose All displayed, program takes a long time and gives Out of Memory error which is understandable. I don't want to do an export of All anyway
If this feature is not available on the FREE VERSION, is there anyway to copy the text and images to something like MSWord? I tried to do a copy and paste to MSWord but they are getting copied without the formatting and images. I could live with not having the images but losing the formatting as well means I have to re-do all the formatting in MSWord.
Any advise will be much appreciated. Thanks in advance.
