iPhone with iOS 6.1.3
PC running Win 8
Current versions of EPIM free.
Calendar imported from Outlook looks fine in EPIM on PC (and syncs well with Android device) but does not sync with EPIM on iOS.
I am able to sync Contacts without a problem but Calendar does not come over from EPIM PC.
I wiped out entire Calendar on iOS (both EPIM's and iOS's) and I still can not get data from PC to sync with iOS calendar.
Suggestions?
Problem Syncing Calendar
Re: Problem Syncing Calendar
Make sure Calendar items are not marked as "Private" in EPIM. PLease post a screenshot of at least one calendar item that does not appear in iOS.
Additionally, is there a reason why items are marked as "Private" by default?
No I am not sure about the procedure to sync the calender, but I will check out with my colleagues and will let you know as soon as possible.
