Feature Request: Better Formatting Notes
- Has thanked: 2 times
Synced notes from EPIM for windows are shown without any formattings, e.g. no color, no underlining, no bold captions and - that would be the most important thing - without table-formatting and without bullets.
Is there any way to get anything of these improvements in one of the next Versions?
Best regards!
Best regards!
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: Feature Request: Better Formatting Notes
Yes, we plan to add the rich text formatting feature in of the upcoming versions. Thanks!
when do you think that it will possible to add the rich text formatting Feature?
Cannot provide any ETA at the moment, unfortunately. But rather sooner then later as we recognize importance of the feature.
Because of the impossibility to read some notices - do you plan to add this feature in near future?
Yes, it's in the list of features with highest priority for implementation.
Is it true, that still in EssentialPIM for Android 4.5 Beta it is not possible to show a correct table grid which was inserted in EssentialPIM for Windows 7.13???
I use the Notes module a lot on my PC, but on my mobile it's almost useless.
It seems that it never ever will be any formatting capabilities on Android (v4.3 and up).
Does anyone out there know a good substitute for EPIM Notes on Android ?
Tables aren't yet supported, unfortunately. Although other text formatting is.Is it true, that still in EssentialPIM for Android 4.5 Beta it is not possible to show a correct table grid which was inserted in EssentialPIM for Windows 7.13???
Feel free to check the 4.5 RC3 version out.It seems that it never ever will be any formatting capabilities on Android (v4.3 and up).
Just got v4.5 on my android mobile.
Now there are many formatting options, happy for that.
But there are no tab stops (on the same line) to create columns.
So, I'm still waiting for table support.
Ok, thanks for the feedback.
- Has thanked: 37 times
- Been thanked: 15 times
Thank you all so much for the formatting!
EPIM Android Pro v6.0.17 -Samsung A52-5G - Android OS v14
EPIM Portable Pro V6.0 RC2
EPIM Desktop Pro V8.64 - Windows 10
