I am having trouble syncing my photos with essential pim. Below is the print out that the phone gives me. Please Help.
java.lang.NumberFormatException: Value out of range for byte: "255"
at java.lang.Byte.parseByte(Byte.java:218)
at java.lang.Byte.parseByte(Byte.java:194)
at com.astonsoft.android.epimsync.managers.EventsManager$EventData.<init>(SourceFile:264)
at com.astonsoft.android.epimsync.models.Command.<init>(SourceFile:134)
at com.astonsoft.android.epimsync.managers.CommandManager.processXMLCommand(SourceFile:124)
at com.astonsoft.android.epimsync.models.AndroidClient.processNextMessage(SourceFile:139)
at com.astonsoft.android.epimsync.models.AndroidClient.doMessageReceived(SourceFile:188)
at com.astonsoft.android.epimsync.models.AndroidClient.access$100(SourceFile:30)
at com.astonsoft.android.epimsync.models.AndroidClient$2.run(SourceFile:321)
Trouble Syncing
- Has thanked: 1412 times
Re: Trouble Syncing
Thanks for the log, the error seems to be related to the lap year. Will fix ASAP in the next minor update of the app.
Re: Trouble Syncing
I'd also appreciate if you could forward me the log file from Windows EPIM, as well. Thanks!
Re: Trouble Syncing
You need to enable the extensive logging feature in Tools->Options->Synchronization, then try to synchronize again. The latest log file can be accessed by clicking on Tools->Options->Synchronization, Browse...
Re: Trouble Syncing
here it is
2016.10.17 10:14:12.504 EssentialPIM Pro 7.13 10/14/2016 2:12 PM
2016.10.17 10:14:12.511 Server started at port 21115
2016.10.17 10:14:12.517 Local IP address(es):
2016.10.17 10:14:12.558 192.168.1.13
2016.10.17 10:14:12.569 Announced by multicast.
Re: Trouble Syncing
There's no synchronization data in the log file, unfortunately. You need to perform synchronization first.
Re: Trouble Syncing
aEssentialPIM Pro 7.13 10/14/2016 2:12 PM
17:51:56.915 9744 gbak:readied database D:\Backup\Backup 151021\01 backup - docs\00 Database Backups\EssentialPim\EssentialPIM\TEST.EPIM for backup
<CUT>
<CUT>
Re: Trouble Syncing
That log file was from the backup process. Android log file should start with AndroidSync.. Please also do not copy-paste contents of the files, just attach the file itself. Thanks!
