I am testing EPIM on Android/Windows.
On Android (7.0) I cannot find any way to customize the screen for the new task. Any customization available there, pls? For example: show/hide options (e.g. show/hide Priority option), add custom options/tags? I have seen two Android apps do this very nicely, but cannot find anything like that here.
Thanks in advance!
Best,
K
New Task configuration
- Been thanked: 1 time
- Has thanked: 1412 times
Re: New Task configuration
Unfortunately there's no option to hide any fields, yet. You can add the new ones, though, by clicking on the "Add field" option.
Thank you for your kind reply. I think I will buy this app because the competition is just terrible. I was quite surprised. nevertheless this is something that should be addressed. i have a pretty large screen and I cannot see all the new task options at the same time (Possibly also because I have Android font set to comfortable level, not too small). I need it because I want to add new tasks fast. Pls take a look at how "SEE A PM, I DONT CONSIDER IT POLITE TO MENTION COMPETITION IN YOUR FORUM" let users configure New task screens. That's the way you should go. Let users choose what is displayed and in what order. A lot of work I assume, that's why I am going to buy to support.
Best,
Karel
Best,
Karel
Will surely have a look as I too think we should consider implementing this feature sooner rather than later. Just don't forget to send me a PM as I don't see any new messages from you, yet.
Update: Got it now, thanks!
Ah, yes, an old anti-spam rule. Sorry about that
