I use a single database that I would like to sync with two phones. Normally I use one phone when work requires that I be local, and I use a seperate phone when traveling. Both phones use EPIM Pro Android. During travel, I normally enter a lot of new data which I would like to sync to EPIM Pro Desktop and then to EPIM Pro Android App on my local phone.
What is the suggested, most reliable method?
How to Sync Single Database with Two Phones
- Has thanked: 1418 times
Re: How to Sync Single Database with Two Phones
You need to create separate synchronization for each of the phones. That's pretty much all to consider Everything else works same way as with a single Android device.
