PC synch failed: NumberFormatException
helixoft
Post by helixoft »
EPIM 7.2, EPIM for Android 4.2.6.
When I try to sync Android from PC, the process starts OK. The progress text shows Contacts, then Events and then it fails with the message that error log is saved to a file. The log file contains:
java.lang.NumberFormatException: Value out of range for byte: "255"
at java.lang.Byte.parseByte(Byte.java:218)
at java.lang.Byte.parseByte(Byte.java:194)
at java.lang.Byte.valueOf(Byte.java:263)
at com.astonsoft.android.epimsync.managers.EventsManager$EventData.<init>(SourceFile:294)
at com.astonsoft.android.epimsync.models.Command.<init>(SourceFile:142)
at com.astonsoft.android.epimsync.managers.CommandManager.processXMLCommand(SourceFile:124)
at com.astonsoft.android.epimsync.models.AndroidClient.processNextMessage(SourceFile:139)
at com.astonsoft.android.epimsync.models.AndroidClient.doMessageReceived(SourceFile:188)
at com.astonsoft.android.epimsync.models.AndroidClient.access$100(SourceFile:30)
at com.astonsoft.android.epimsync.models.AndroidClient$2.run(SourceFile:321)
Best regards
Re: PC synch failed: NumberFormatException
Please update to Android EPIM 4.5.
helixoft
Post by helixoft »
Strange, I tried to update EPIM for Android in the morning, but there was no version 4.5 available in the store. Now it was there. Installed 4.5 and everything went fine.
Thank you
It takes some time for the new version to propagate to all Google Play users. Anyway, glad it's working now and thanks for the info!
