first of all thanks for the new Notes. It's so much better than before!!! Good work!!!
I found a small glitch: only when you add a new tree and then you create a new note/leaf by tapping the yellow button in the bottom right of the screen instead of creating immediately a new note, the yellow button becomes white and you have to tap it again to create the note. So instead of one tap like usual you have to tap twice.
Little suggestion: in the new toolbar for editing notes would be possible to change the color of the icons A and A to match the color currently selected? Example: when I select yellow it would be nice that the A or A icon becomes yellow too to remember me the color selected. It would be useful when I write using different color and I stop and later after minutes resume writing. It would be similar to how MS Office or LibreoOffice toolbars work.
Small glitch in Notes and suggestion
- Has thanked: 1412 times
Re: Small glitch in Notes and suggestion
Partially confirm the glitch, will try to fix it in the next minor update.I found a small glitch: only when you add a new tree and then you create a new note/leaf by tapping the yellow button in the bottom right of the screen instead of creating immediately a new note, the yellow button becomes white and you have to tap it again to create the note. So instead of one tap like usual you have to tap twice.
Will try to implement in the next build, as well.Little suggestion: in the new toolbar for editing notes would be possible to change the color of the icons A and A to match the color currently selected? Example: when I select yellow it would be nice that the A or A icon becomes yellow too to remember me the color selected. It would be useful when I write using different color and I stop and later after minutes resume writing. It would be similar to how MS Office or LibreoOffice toolbars work.
Thanks!
- Has thanked: 26 times
- Been thanked: 12 times
Hi, I've updated to 4.5.1. Glitch is better (button doesn't become white now) but many times first tap is unresponsive. You have to tap twice to create a new note. Happens only with a new tree and with the first new note.admin wrote:Partially confirm the glitch, will try to fix it in the next minor update.I found a small glitch: only when you add a new tree and then you create a new note/leaf by tapping the yellow button in the bottom right of the screen instead of creating immediately a new note, the yellow button becomes white and you have to tap it again to create the note. So instead of one tap like usual you have to tap twice.
Will try to investigate further, thanks.
