Membership of contacts is not transferred from EPIM Windows (in my case 7.24, but this existed also in previous 7.x versions) Pro Portable to EPIM Android 4.6/4.7beta. The groups are there, they are synced, but remain empty. If I edit in Android a contact and add the group (similar to Windows), than I see that contact as a member of the group.
In all cases the membership of the group in EPIM Android contacts is empty. This happens on my phone and tablet and in both cases they are set as system accounts.
Group membership not synced
Re: Group membership not synced
I'm unable to reproduce that unfortunately. Do you use a 2-way sync option? Will you be able to reproduce that with a new test EPIM database file? If yes, please forward me the log file via PM, will have a look. Thanks!
- PeCe
- Has thanked: 101 times
- Been thanked: 329 times
I use 1-way sync and no I could not reproduce the problem.
I tested it on my tablet with a test database and there it worked fine. All group memberships remained with the contacts.
After that cleaned the sync-data and I synced my standard database again. Now it works fine. All group memberships are back again.
On my phone the groups are still zero.
Tomorrow I will clean the data on the phone too and after that sync again. I guess then this problem will be solved.
So it looks like a strange behaviour, but a problem that can be solved by cleaning and synchronize again.
Good to know, thanks for the info!
