Access Violation with Caldav
Postby scdzaak » Wed Oct 26, 2011 10:10 am
Dear Support,
I am 30 day trial user with the EssentialPIM Pro version 4.24
I will use the EPIM in combination with the caldav replication possiblity.
In the next two screens you can see the error after I click the menu option: Bestand (file) - Synchroniasatie (Sync) - Atera.
The atera server is a hosted Zarafa server with caldav activated.
Can this error be repaired, or updated in a next version.
When this error is fixed I can use (and buy) the program ..
Kind regards,
Eric
Caldav AV error
Caldav setup
scdzaak
Have thanks: 0 time
Re: Access Violation with Caldav
Postby Max » Wed Oct 26, 2011 2:06 pm
do you know if we could anywhere connect to Zarafa to test? Otherwise we would need to install it on our machines and it would take time.
viewtopic.php?f=1&t=13483
For this message the author Max has received thanks:
scdzaak (Wed Oct 26, 2011 2:53 pm)
Rating: 25%
Have thanks: 101 times
Postby scdzaak » Wed Oct 26, 2011 2:53 pm
Yes,
No problem at all.
Please send an email to info [add] syscodata.nl
And I will send you the user account on zarafa server !
Regards,
Eric
scdzaak
Have thanks: 0 time
Postby scdzaak » Fri Oct 28, 2011 4:46 pm
All,
Working is in progress !
Many tnx to r&d ....
Eric
scdzaak
Have thanks: 0 time
Return to Support
Who is online
Users browsing this forum: No registered users and 1 guest
