EssentialPIM Pro 4.5 Release Candidate 2 - Message Rules
Postby ianmonster » Mon Nov 14, 2011 4:38 am
Hello;
I am not sure if this is the right place to post this.
Iam Currently using EPIM Pro 4.24, then got curious about EssentialPIM Pro 4.5 Release Candidate 2, which I tried to use, using the same EPIM file from the EPIM Pro 4.24.
The EssentialPIM Pro 4.5 Release Candidate 2 is great, the new function which involve the attachments especially however, I noticed two problems when I tried using this.
1. When I tried to create a new message rule, it gets saved but when I try to edit this new message rule, it becomes blank.
2. Old Message Rules remain but when you try to edit, all conditions become empty as well (generally, the message rules function don't work properly in EssentialPIM Pro 4.5 Release Candidate 2.)
Thanks!
ianmonster
Has thanked: 0 time
Have thanks: 0 time
Re: EssentialPIM Pro 4.5 Release Candidate 2 - Message Rules
Postby Max » Mon Nov 14, 2011 8:50 am
Are you using Desktop or Portable?
viewtopic.php?f=1&t=13483
Have thanks: 98 times
Postby PeCe » Mon Nov 14, 2011 8:47 pm
I tried this with 4.5 rc2 (portable PRO), with a new database and the existing database.
Also with one and multiple accounts.
For me the message rules work as they should. I can add new rules and also edit rules, they remain there, do not become blanked.
Can you create a new database and check in on that file.
Also as Max asked can you answer,
if you are using the Desktop or Portable version?
and are you using (did the testing) with the PRO or FREE version?
Maybe then we can determinate why it doesn't work for you.
Dutch translator for EPIM
EssentialPIM Pro portable 5.54 on Windows 7 // Android EPIM 2.1.4
PeCe
Has thanked: 13 times
Have thanks: 49 times
Postby nebrit » Mon Nov 14, 2011 11:02 pm
I tried it and gives the error that says, bug exists and the rules there are blank. The steps are, you create new folders, and given rules, more rules by folder, by subject, recipient, body of the email. You create multiple folders with multiple rules. It saves the database. Pressed send and receive, within the rules as the content is deleted when you press edit the rule is blank inside.
My PORTABLE PRO version 4.5 rc2.
bug Rules.jpg (226.17 KiB) Viewed 1344 times
The Spanish and Catalan translator of EssentialPIM
EssentialPIM Pro 5.03 and/or the latest beta version, Windows 7 and Ubuntu 12.04
www.lexnos.com
nebrit
Has thanked: 0 time
Have thanks: 13 times
Postby nebrit » Mon Nov 28, 2011 9:25 am
Hi!!
By creating message rules, all emails received with attachments, attachments do not arrive. I tried with three different database and different rules.
It is serious, not getting the emails with attachments when creating new rules of the message recipient, and body content.
Thank you.
www.lexnos.com
nebrit
Has thanked: 0 time
Postby nebrit » Mon Nov 28, 2011 9:36 am
If I delete the message rules created with various options, then receive attachments ...
www.lexnos.com
nebrit
Has thanked: 0 time
Postby Max » Mon Nov 28, 2011 11:18 am
nebrit, then we need to know the exact particular rule that is causing the trouble (screenshots are best). So far we were not able to reproduce it.
Postby nebrit » Mon Nov 28, 2011 11:40 am
The process is as follows:
With new rules do not receive attachments enabled.
With these new rules disabled receive attachments. Attachments not receiving any incoming mail, whether or not to do with the rules.
Step 1
RULES 1.JPG (221.61 KiB) Viewed 1193 times
Step 2
RULES 2.JPG (219.69 KiB) Viewed 1193 times
Step 3
RULES 3.JPG (223.99 KiB) Viewed 1193 times
Step 4
RULES 4.JPG (239.92 KiB) Viewed 1193 times
www.lexnos.com
nebrit
Has thanked: 0 time
Postby nebrit » Fri Dec 02, 2011 12:19 pm
Hello!!
In version 4.51 does not solve the problem
With new rules do not can receive attachments with enabled rules.
With these new rules disabled can receive attachments. Attachments not receiving any incoming mail, whether or not to do with the rules.
BUG RULES 4.51.JPG (269.17 KiB) Viewed 1155 times
www.lexnos.com
nebrit
Has thanked: 0 time
Postby Max » Fri Dec 02, 2011 12:25 pm
Thank you, I will try to reproduce. Is it POP3 or IMAP account?
Postby nebrit » Fri Dec 02, 2011 12:41 pm
Hello!!
There are several accounts, both POP3 and IMAP, please find attached configurations.
I hope you can solve a problem that has existed for many versions and is quite serious.
It happens to many users.
Thanls
IMAP
POP3
www.lexnos.com
nebrit
Has thanked: 0 time
Postby nebrit » Wed Dec 07, 2011 9:47 am
Hi!
Reproduce the bug? Be corrected in the next release? or need more information?
www.lexnos.com
nebrit
Has thanked: 0 time
Postby nebrit » Sun Dec 25, 2011 10:00 pm
Hi!!
The bug persists in version 4.52
Not resolved. It is a grave bug. When you are going to solve?
www.lexnos.com
nebrit
Has thanked: 0 time
Postby Max » Wed Dec 28, 2011 2:29 pm
The problem is, looks like you are the only one having this problem (At least on the forum no similar messages).
We can not reproduce the problem. It may depend on a lot of details (that's why we are not able to reproduce it)
Maybe you could give us a copy of your database so that we could see the problem. Otherwise we do not have any solution at this moment.
Postby nebrit » Wed Dec 28, 2011 2:36 pm
I sent a copy of the database, however I put here the message you send to epimsuport unanswered ...
At the forum I am not alone, but two friends, my cousin and my brother all have the same problem.
________
Hello!
I'm Javier Antonio Nisa Avila - Essential PIM PRO portable 4.52 - windows 7
The bug that is described here viewtopic.php?f=1&t=11370 is not fixed in 4.52
I sent a copy of my database in the following link to download http://www.box.com/s/gdesbvj9xhfdbd7l5r9m the password of database are "EDITED"
In folder Inbox are two emails with the title "Su factura 605721866 del 01.05.2011" of December 25. The two are equal and should have the same attachment. But one has no attachment.
That is because one has received no activated message rules, and another message the rules enabled.
The rules of message failures are those that are can be found in Tools -> Message Rules. The rules that cause the failure to activate are "Vida Laboral Sevilla 3" and "UGT"
It is a mistake that I think is serious. If you need anything else please ask me
I can confirm that you have received this message.
www.lexnos.com
nebrit
Has thanked: 0 time
Next
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 2 guests
