by Marien » Sun May 27, 2012 10:47 pm
Hi Max,
I have a standard 17-inch monitor, as many, or most, people probably do. When I set EPIM to Two-Week-View, 14 very narrow columns appear next to each other, separated, moreover, by blank lines, which appear only in Week-View. This leaves insufficient room for readable entries, however brief:
- only 7 to 8 digits per entry, with the Navigation Pane closed
- only 5 to 6 digits per entry, with the Navigation Pane open, the probable situation with many or most users.
In EPIM Month-View, the 7 columns appear to be wide enough, but the drawback is here that per day only 4 entries (lines) are visible (without scrolling), which probably is insufficient for most users.
So I suggest (again):
- make Two-Week-View as Month-View, but with only 2 instead of 5 rows.
- eliminate the vertical blank separation lines between the days, to help free up necessary space.
I trust that most users will then be able to make a (still) better use of EPIM. If I remember well, in the past there have been more suggestions supporting this approach.
Marien
