Android version
Android version
EssentialPIM is actually the best PIM ever. I removed lot of other tools (email clients, outliner and so on) moving all my infos to EPIM. But... I miss some features. One of these features is the possibility to run EPIM on my Android Device. I was using Evernote that works great on Android. I used it to record voice notes, to take photos and so on, and after the sync i had all those infos in my desktop and notebook. I would like ot do the same using EPIM.
Is it possible for you to create an android version of the EPIM?
Thank you.
Thank you.
Re: Android version
yes, we are working on an Android version, it should be released within months.
- Has thanked: 6 times
Re: Android version
Android version will be a great thing. Now I have problems to look at/update my calendar, contacts, ... lets say "on the road" I want to use this asap.
Will it be available free for pro users?
Looking forward to this!
Xa4
Xa4
Epim pro lifetime license user
- Has thanked: 32 times
- Been thanked: 54 times
Re: Android version
+1
It sounds great - a lite version as Android application (calendar, tasks, contacts, notes), yes please.
Jiri Humplik
http://www.epimcz.wbs.cz
Re: Android version
Your ideas for the lite version (calendar, tasks, contacts, notes) would be my preference too!Georgo2010 wrote:+1
Re: Android version
People, have you been trying to search for EssentialPIM in Google Play Store lately? If not, I encourage you to do that
You will find an app that allows synchronization of Android Calendar and Contacts (built-in ones for the moment) along with To Dos and Passwords (our own creation) with EssentialPIM. To Dos and Passwords are two fully working modules that closely correlate with EssentialPIM’s philosophy and should be a joy to use for all EPIM’s users.
Later on we plan to add the Notes module (and synchronization with it) and after that Calendar and Contacts will follow. Stay tuned and please report your thoughts and suggestions about current version of the Android application.
Oh, and one more thing. EssentialPIM for Android will work with EssentialPIM 5.0 version only. You can download the first beta versions (prepare to find some very interesting features in the new version) from here:
Desktop: http://www.essentialpim.com/download/be ... MPro50.exe
Portable: http://www.essentialpim.com/download/be ... Port50.zip
Important! Please backup your current EPIM database file first (although, there’s an automatic backup but Beta is Beta, right) before opening it with the Beta version.
Re: Android version
I am disappointed. What's so great about this version EPIM 5.0B1?admin wrote:People, have you been trying to search for EssentialPIM in Google Play Store lately? If not, I encourage you to do that
- unable to open database from version 4.5
- very unstable
Thank you I don ´t want this!
- known problem from previous versions after open (new) database
- EPIM 5B1 - 01.png (8.52 KiB) Viewed 6327 times
Jiri Humplik
Re: Android version
What does the error message say? And if you could copy your database from 4.54 into a new file, then open it with 4.54, delete all the sensitive data and then forward to us, we will then try to fix the issue you're having.
Re: Android version
OK, I´m sending you right now backup of my database (without sensitive data) with error report to "errors".admin wrote:What does the error message say? And if you could copy your database from 4.54 into a new file, then open it with 4.54, delete all the sensitive data and then forward to us, we will then try to fix the issue you're having.
- EPIM 5B1 - 02.png (11.77 KiB) Viewed 6324 times
Jiri Humplik
