Phone and Fax dialing
Postby Steve Gutry » Sun May 06, 2007 11:43 pm
Is there any chance of having the program able to dial a phone number or to send a fax?
Steve Gutry
Postby Max » Mon May 07, 2007 8:43 am
so far no such plans.
viewtopic.php?f=1&t=13483
Have thanks: 98 times
Re:
Postby Brjlk » Mon Jul 30, 2012 10:12 am
Max wrote:Hello,
And now in 2012, is there any plan about this?
If not, what workaround is there to reading the contact's number from IPIM PC & dial manually?
John
Brjlk
Have thanks: 2 times
Re: Phone and Fax dialing
Postby Max » Mon Jul 30, 2012 8:33 pm
There were not sufficient number of requests for these features.
You can copy/paste contact's number.
Postby Brjlk » Tue Jul 31, 2012 4:45 am
Max wrote:There were not sufficient number of requests for these features.
Thanks, I understand.
I suppose most people call from their mobile phones, instead of from a fixed phone.
John
Brjlk
Postby zarrarnyc » Sat Dec 22, 2012 11:16 pm
If I may enlighten this topic. Dedicated CRMs such as SugarCRM, Salesforce, Goldmine some versions of Outlook as well as other software are capable to dialing the contact's phone number or sending a fax. For many reasons, there is a need to step away from cloud services, or from Outlook and the complexities and costs of Salesforce and SugarCRM. If EssentialPim were to have a dialing feature, which is not hard to implement since it links in to the PCs phone dialer, chances are that you would see a large migration from these other softwares. There is a void between high end CRM, and the low end PIM tools. If people had not requested this feature is because no one know that by requesting a feature it would materialize.
I assumed, that since EssentialPIM is an alternative to Outlook, it would by default have a dialing button. The reason for having a PIM or contact manager in the first place is because one needs to managage contacts which have outrgrown other organic means like pen and paper, phonebooks and the sort. If you are using a contact manager, or PIM, then a dialer is essential.
I have downloaded Essential PIM in hopes of having a dialer and it does not. I don't want to use Outlook, or any other cloud based services. The need for a desktop manager with mobile device syn is important. Having a dialer no matter if it is a mobile phone, or desktop VOIP setup is important. There are times when you need to use a headset on a VOIP instead of a mobile phones. The need is there, and you should implement this feature. I am ready to buy if you have this feature.
zarrarnyc
Has thanked: 0 time
Have thanks: 0 time
Postby Max » Mon Dec 24, 2012 12:25 pm
Than you for you opinion, we will consider it.
Postby Brjlk » Tue Dec 25, 2012 6:24 am
Max wrote:Than you for you opinion, we will consider it.
Thanks, this is a feature I also find useful & had requested
John
Brjlk
Postby catsaccounting » Thu Apr 11, 2013 9:24 pm
A LOT of us would like the dialer / fax feature but just don't say anything because we are already using Windows Fax and Scan or something and used to entering the contact info in yet ANOTHER location - - sure would be nice if EssentialPIM had this feature, though . . .
Terry Cranford
CATS Accounting
catsaccounting@yahoo.com
catsaccounting
Has thanked: 0 time
Have thanks: 0 time
Return to Suggestions
Who is online
Users browsing this forum: Exabot [Bot] and 1 guest
