Problem Connecting Server
I can't connect to the server.
Can administrator help me?
Follow video: https://drive.google.com/file/d/150awLM ... sp=sharing
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Problem Connecting Server
Do you have Firebird server installed on your local PC? If yes, you can simply use "localhost" (without quotes) to specify the server's address.
Hello Administrator.
I didn't understand very well.
If possible, please send me a step-by-step guide on how to use LocalHost.
Note: Yes, I am using Firebird on my PC.
Simply type 'localhost' (no quotes) in the server address field.
Please check this video: https://drive.google.com/file/d/10S6r34 ... sp=sharing
Were you able to establish a connection? Based on the latest video you posted, it appears that there is no Firebird server installed on your local PC.
I was able to connect to my PC, but the client's PC was not connecting. What is the procedure to connect the client PC?
See the images: https://drive.google.com/file/d/10zON9g ... sp=sharing
Administrador consegui conectar o cliente no PC(servidor).
Eu criei uma tarefa no PC(servidor) e também criei um alarme para esta tarefa, mas o alarme desta tarefa está sendo acionada(mostrado)
no PC cliente.
É possível fazer com que uma tarefa criada no meu PC(servidor) nao seja acionada(mostrada) no PC cliente? se sim, por favor me explica como fazer isso.
no PC cliente.
Hello Adm,
How do I configure this task (in the link below) to emit an audible alarm EVERY DAY to remind me of these tasks at a specific time?
Link: https://drive.google.com/file/d/11CJiAL ... sp=sharing
- Beta Team
- Has thanked: 5 times
- Been thanked: 3 times
Have a copy of an old EPIM database that was associated with a server. The original file and the server PC was damaged. Am just trying to open the backup copy to be able to move over information to another EPIM database but haven't been able to. Is there any way to access directly? It still refers to the network when trying to open.
- Beta Team
Hoper, please note that "localhost" is used for connecting to your local PC. If you have a server installed on another PC and the EPIM database file is located on that PC as well, you will need to enter the IP address of that PC instead. For more detailed information on connecting to a server, you can refer to the documentation provided at https://www.essentialpim.com/help/conne ... verhhh.htm.
Regarding your question about reminders, you have the flexibility to add as many reminders as you need. Alternatively, if you prefer, you can simply postpone a single reminder by one day when it appears.
