norsea wrote:When using Message Rules:
Create a new rule.
Move it UP
When it gets to be the top most rule an error message pops up and a window is opened for the error log to be emailed to errors@essentialpim.com
Select the send button.
Nothing, absolutely nothing happens.
This has been going on since Beta 3 when I first installed EPim.
When I try to copy the message in the window, as soon as I select any are of the body of the message in the window it is put behind the main EPim window.
The only way I can capture the data is to copy it when the initial error window is open.
I have sent several of these in but, apparently no one knows what to do, OR the info is not getting to the right person.
Jim, who has given up trying to copy and paste the info after having sent it in several times. It's just to cumbersome a process to do as much as I would have to every time I move a message to the top of the rules....
Just had yet another error message email generated that cannot be sent. Error info follows:
Whitespace is not allowed at this location.
Line: 7
<div><a href="epim://C:\Documents and Se.
Exception log with detailed tech info. Generated on 7/14/2012 1:18 PM.
Application title: Jim.epim - EssentialPIM Pro
Application file: C:\Progra~1\Essent~1\EssentialPIM.exe
Application: EssentialPIM Pro 5.0 RC3
Exception class: EDOMParseError
Exception message: Whitespace is not allowed at this location.
Line: 7
Exception address: 008084DB
Main thread ID = 5136
Exception thread ID = 5136
Object Logs:
14231437 DBSave
14231437 AppMinimize
14162625 SetViewMode 5
14130187 SetViewMode OK
14129843 TNote Store 193918211158006190
14129781 TNoteTab Store 497141886690020483
14129781 TNoteTab Change 497141886690020483
14129781 TNote Change 193918211158006190
14129781 SetViewMode 2
14125437 SetViewMode OK
14125296 TToDo Store 306664647039752464
14125281 TToDo Change 325177551083017810
14125281 TToDo Change 306664647039752464
14125281 SetViewMode 3
14118984 SetViewMode OK
14231484 ExceptionDialog TextMemo
14170468 MainForm FormPan FormPan2 ToDosForm TntPageControl1 NotesTS NotesMem RichViewEdit
14167312 ExceptionDialog SendBtn
14163265 ExceptionDialog OkBtn
14162703 ExceptionDialog TextMemo
14147265 MainForm FormPan FormPan2 ToDosForm TntPageControl1 NotesTS NotesMem RichViewEdit
14146265 HyperlinkDialog TntPageControl1 ItemTS BrowseBtn
14144265 SelLinksDialog ItemsVT
14140265 SelLinksDialog ToolBar1 Panel2 ModulesCB
14139265 SelLinksDialog ToolBar1 Panel1 FindCB
Exception stack
Stack list, generated 7/14/2012 1:17 PM
(0000D514){ntdll.dll } [7C90E514]
Call stack for main thread
Stack list, generated 7/14/2012 1:18 PM
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Memory: 2047; free 2001
Display : 1366x768 pixels, 32 bpp
PrevExceptions:
14170453 Whitespace is not allowed at this location.
Line: 7
