EssentialPIM 7.6 Release Candidate 1 is available!
Been thanked: 363 times
we are excited to announce general availability or 7.6 version Release Candidate.
This is a chance to safely try out new features among the first. There is no database conversion between version 7.5 and 7.6, thus your database can be opened in any of them.
It has many new features and improvements to each and every module, so there is lots to explore!
Downloads:
Pro:
EPIM Pro Desktop
EPIM Pro Portable
Free:
EPIM Free Desktop
EPIM Free Portable
New features:
  • It is now possible to send mass-mail Newsletters with Rich-text
  • You will now always know whenever something is filtered in view- there is a special "Customized view" line
  • Tags and Attachments are synchronized with EPIM Android
  • Appointment Reminder window has a setting "stay on top"
  • To/From addresses in email now have features to copy/add to addressbook /compose email/create rule
  • In quick search it is now possible to use operators AND / OR
  • "Show in Calendar" default option for Tasks
  • It is now possible to send Task/Appointment as iCal and Contact as vCard via email
  • Message rules now have additional parameter "is/isn't in Contacts"
  • It is now possible to forward multiple emails at once*
  • It is possible to import iCal file by dragging iCal file into Calendar window
  • It is now possible to limit some synchronizations by date range
  • Task templates now remember dates as well
  • It is possible to Convert Contacts to Tasks/Appointments
Improvements & Fixes:
  • Tasks import from iCal improved
  • Improved copy/pasting from browser to Notes
  • iCloud synchronization fixes
  • Fixed synchronization to Outlook.com
  • Improved To Do copy-pasting with Child To Do's
  • Improved synchronization with Android EPIM
  • Improved moving Appointment series
  • Improved Advanced Search
  • Improved drag and drop of Contacts and Passwords into the groups
  • EPIM Today can now preview To-Do's with up to 99 days
*available in Pro version only
Android EPIM 5.3 Beta
There’s also the new Android EPIM 5.3 Beta version available. It will allow you to synchronize tags, attachments and contacts/passwords groups hierarchy. Plus, it offers a substantial list of other new and useful features.
The new version is available either from the Google Play store (you need to be registered as a Beta tester for our app to get the latest update) or from the following direct download link: www.essentialpim.com/download/beta/EssentialPIM53.apk.
liu_tao58
Re: EssentialPIM 7.6 Release Candidate 1 is available!
Post by liu_tao58 »
Wonderful! I like your software, keep going!
a8907433
Been thanked: 118 times
Post by a8907433 »
PGP is not working anymore!
When clicking on Tools/PGP...... nothing happens.
Has thanked: 797 times
Been thanked: 427 times
Confirm the issue with PGP will fix, thanks!
StevanD
Post by StevanD »
Hi Max,
Thanks for solving the issue with losing customised view when changing Tree/Consolidated views!
I like this Customized filter.
I like also you added Due/Start date(regular/detailed) filer on the left column.
Keep good work guys!
Stevan
DFNet
Has thanked: 8 times
Been thanked: 5 times
Post by DFNet »
Hi Max,
Sync with Android is very slow. The process stops responding on the notes synchronization.
I have already completed a first synchronization of all note attachments, but the subsequent ones are very slow. Android EPIM v.5.3 beta
EssentilPIM PRO Lifetime since 2011
jaffcat
Post by jaffcat »
Android app crashes and needs to shutdown
Jaffcat
Pathfinder
Post by Pathfinder »
Hi Max,
with me the sync to Android works now :)
Yes it is very slow... but first time after a long time I have even the subsequent and attachements.
Only thing is, that with each syncing it got every folder doubled, tribbled, ...
I will delete the Android Database and run a fresh sync from scratch. Then try a second sync and give feedback again.
Best regards
Juergen
Everything is possible - believe in yourself
todd
Post by todd »
Hi
I mainly use the notes and calendar modules. I am running windows 10 pro 64 bit.
So far the only new problem I see is when I create a child note, then promote it using the shortcut key (ctl-shift-leftarrow), it pops up to the top of the list instead of staying below the item I just inserted it into.
Other than that, some other problems that I've noticed also remain:
1. Whenever I install a new upgrade, my keyboard shortcuts revert back to the defaults instead of retaining the keys I've customized.
2. Also - I only use some of the modules. When I install an upgrade, my previous settings are ignored and I have to again designate which modules to show because all modules are now enabled again.
3. When I sync to my android tablet (epim for android 5.2.1) my notes come over in a different order from the way I have them arranged in the windows version. Can't they just stay in the same order?
And one small wish item, especially because of problem #1 above: When I click on a keyboard shortcut in the options dialog, why can't I just change the shortcut right there instead of having to click on the shortcut and then go down to the shortcut key box to make the change??
All that being said, I've had a lifetime license for Epim since 2015 and the product just keeps getting better, so keep up the good work.
Todd
todd, thank you for your comments, we will consider and will try to investigate and improve. Will revert on Android issue as well.
Are you using Pro or Free version, Desktop or Portable?
todd
Post by todd »
Hi Max
I'm using the Pro Desktop version under windows and the free version under android.
Todd
DFNet, you mean slow comparing to the previous versions? Does that only affect the notes module or some others, as well?
Jaffcat, please do not duplicate your posts. The one you posted in another topic would be enough for us to react :)
Juergen, thanks will be waiting for the update.
Todd, please check your sorting order for notes in Android EPIM.
jaffcat
Post by jaffcat »
Apologies, I realized it was in the the wrong thread, but couldn't delete.
Jaffcat
DFNet
Post by DFNet »
admin wrote:
Mon Oct 23, 2017 8:42 am
Yes, comparing to the previous version and yes that only affect the notes module.
Thanks, will check that out.
