EPIM-Mail with Emoji
christian_bayern
Has thanked: 4 times
Been thanked: 4 times
Post by christian_bayern »
is there a way to use Emojis in a Mail?
Like the Smilies in this forum :)
Thanks,
Chris
a8907433
Been thanked: 118 times
Re: EPIM-Mail with Emoji
Post by a8907433 »
Hi!
Unfortunately EPIM has no buildt in Emojis. (Max- PLEASE!!!)
I downloaded Emojis from internet, saved the pics in an EPIM-folder, and use them as normal pictures (Insert/Image).
Been thanked: 363 times
suggestion noted, thank you!
pela
Has thanked: 11 times
Been thanked: 17 times
Post by pela »
Guten Tag
Kurze Nachfrage , da es schon mehrere Jahre her.
Kommt da was in naher Zufunft ?
Mit dem Trick im Ordner Ablegen , ist nicht so das ware.
MfG
übersetzt mit Google.
Good day
Short demand since it was several years ago.
Is there something coming in the near future?
With the trick in the file folder is not so that.
Kind regards
translated with Google.
HFSchrOEder
Post by HFSchrOEder »
Unter Windows (10) lassen sich mit der Tastenkombination "WIN" und "." Emojis einfügen. 😁
