I have been long time user of EPIM and EPIM Mobile with google.
Since 8.11 I am noticing many strange and inconsistent sync issues between EPIM and Google.
Yes I occasionally get the duplicates and I am fine with that but noticing errors I have never seen before including.
Date shifts
Deleted new items on sync
Events that have date ranges adjusted
I fix what is damaged it works fine all day even testing... next day similar problems.
Sometimes I have to delete and recreate the sync process for it to work at all.
A few minutes ago after EPIM deleted all new entries when I sync to google I decided to restart EPIM and sure enough it is working again. This is indicative of a bug typically,
I am working with support and sending them logs.
I get the impression there is a bug in 8.11 with sync.
I am spending too much time on this and thinking of rolling back to older version, any thoughts on this this problem. I figured I am probably not the only person running into this problem.
Dan
Sync issues
