Hello
I'm really new here and I'm trying to understand if this program is ok for my company
a) Add an appointment to a contact
If I add a contact I would like know if it's possible add a appointment or a task to the contact
I mean
If I have the contact PHIL from the Phil schede I would like add, for example, on MONDAY at 9.00 am CALL PHIL
or from the calendar schedule an appointment with PHIL
How I can do it?
2) I don't understand well the difference between CALENDAR and TASKS
3) How can I create groups of contacts?
Join a appointment or a task with a contact
- Been thanked: 1 time
Re: Join a appointment or a task with a contact
1.- You can create a new appointment and link to it from the Contact
2.- You can use either, but generally Calendar is something that keeps your day schedule, while, Tasks are not necessarily tied to days
3.- I suppose you are using Pro version. When in Contacts module, use Actions-> New Group menu
