Hello
With this new release we can now "Set Shortcuts for creating any type of new items". Can you elaborate on what this new functionality is?
I would really love to be able to create a shortcut that would archive a message to a folder and have the ability to set that folder. For example Ctrl+E would move an email to a folder named Archive. Perhaps I should ask this question under suggestions?
9.3 Set Shortcuts
- Has thanked: 1419 times
Re: 9.3 Set Shortcuts
Yep, this sounds more like a suggestion. The new feature allows you to create a new mail message by pressing the "Ins" key on your keyboard, for instance. You're also able to change this shortcut to another one in options.
No need, I'll move this topic in there, it's going to be quicker
I see, moved this one back into General Discussion then
