Italian.lng Pro 1.5 beta 3 Update
Italian language update to EssentialPim Pro 1.5 beta 3
- Pro Italian.zip
- (4.6 KiB) Downloaded 670 times
- Has thanked: 1418 times
ikkyu, thanks for the updated language file!
Yes, there's going to be only one single language file as for the Free as for the Pro versions of EssentialPIM starting from 1.6 version.
New revision, small changes...
Works in both free and pro (tested).
E' possibile personalizzare la traduzione. Basta aprire il file con un editor di testo in grado di gestire UTF-8 e cambiare secondo le proprie esigenze.
- Italian.zip
- Italian.lng
- (4.58 KiB) Downloaded 841 times
