<FRENCH> v5.57 (with Android full translation)
Golfy
Has thanked: 14 times
Been thanked: 24 times
Post by Golfy »
I'm late, sorry for no comment
French.lng
5.57 français
(87.11 KiB) Downloaded 184 times
Golfy
Re: <FRENCH> v5.57 (with Android full translation)
Post by Golfy »
Ok, I've passed two hours on the file, hunting last mispells and forgotten translation !!!
here are corrections :
- dictionnary corrections (thanks to Notepad++ and french dictionary integrated)
- last forgotten sentences (again thanks to red underline on english words :wink: )
However, something is wrong with my Android EPIM... the following section (from french.lng) means that short days will be translate... but
<string-array name="td_weekdays_short">
<item>Lun</item>
<item>Mar</item>
<item>Mer</item>
<item>Jeu</item>
<item>Ven</item>
<item>Sam</item>
<item>Dim</item>
The following picture shows it isn't (for views buttons too) :(
I've forced EPIM in french of course (on Android)
Any idea ? (my Android phone has an english MIUI kernel)
By the way, a translation couldn't fit in dialog box (Export Note). See picture joined !
Export size problem
Export size problem
French.lng
oct 22 files (fully corrected)
(87.55 KiB) Downloaded 173 times
EPIM Android localization language
EPIM Android.png (45.89 KiB) Viewed 4166 times
Has thanked: 779 times
Been thanked: 411 times
Golfy, are you on the latest EPIM Android version (2.4)? If not, please update.
With regards to the export dialog window - will make it bigger, thanks!
Golfy
Post by Golfy »
I'm with 2.4 of course !
Thanks, confirm the issue, will fix in the next version.
