No Polish language in EPIM 6.0 RC1
MEgler
Post by MEgler »
There is no Polish language included to EPIM 6.0 RC1. Please include it.
Has thanked: 779 times
Been thanked: 411 times
Re: No Polish language in EPIM 6.0 RC1
It is included, you can check the Languages folder. It's not appearing in the list of available languages because some important information in the beginning of the file is missing, like language name and language ID. Will fix that in the next release, thanks.
mariogda
Post by mariogda »
I just installed latest version of EssentialPIM 6 PRO (stable) on my desktop and everything looks great except above mentioned translation. I am happy to use english language however just wanted to know if there is any way to set polish language? Translation file (Polish.lng) exists so, just wondered if it is possible to turn it on somehow.
Marek
Yes, please use the attached Polish language file instead of the one included in 6.0. Will fix the situation in the next minor release of the program.
Polish.lng
(65.14 KiB) Downloaded 347 times
mariogda
Post by mariogda »
great thank you for your help :) It works perfectly now.
Marek
