<FRENCH> translation
crazyforjags
Re: <FRENCH> translation
Post by crazyforjags »
Hi there, looks like that "Éléments supprimés" is now displayed as only "Éléments"
Golfy
Has thanked: 14 times
Been thanked: 24 times
Post by Golfy »
From my tests with 8.03, it's OK. Which version and FAI are you using ?
Please check with language file french.lng, on line 6000
6000=Boite de Réception|Boite d'envoi|Éléments envoyés|Éléments supprimés|Brouillons|Modèles|Indésirables
2018-08-18 22_11_13-Window.png (5.36 KiB) Viewed 88 times
crazyforjags
Looks like it did not update to 8.03 I have 02. Updates and text OK...Thanks
Golfy
Post by Golfy »
The translation file is V8.02 : it's normal.
Golfy
Post by Golfy »
french translation isn't dead :wink:
Here is the v8.52 french translation file.
I'm feeling a bit old when looking on the time I've spent in translating EPIM. :roll:
French.lng
(108.19 KiB) Downloaded 8 times
