Export/import ICS file from/to EPIM
roze
Post by roze »
I am using EPIM for several years, but now I guess I must stop :( .
EPIM does not make a reliable and functional sync between PC and Google account.
I tried to resolve this manual by first sync between EPIM-> Google...
When I see all my Calendars items in Calendars/Table I see in status bar of EPIM summary 1269 items.
When I export all my Calendars categories to CSV I see message window about exported 1269 items.
When I export all my Calendars categories to iCal I see message window about exported 94 items. # OK, OK - I have a lot of 'out of date' items or repeating items, but ...->
If I do import of exported iCal file to the new EPIM base so expectedly a lot of calendar items is missing.
The attempts with export/import I did out of despairy. EPIM wasn't s able to make proper first sync with my Google account.
I thought I do EPIM export and then import to Google, but it is not possible for missing items in the exported iCal file.
I tried this wit EPIM 5.03 and also wirt EPIM 5.5 Beta2.
See also: viewtopic.php?f=1&t=13220&p=55515#p55515
Been thanked: 363 times
Re: Export/import ICS file from/to EPIM
Is the only complaint about Google sync is the problem with characters (like here: viewtopic.php?f=1&t=13220&p=55515#p55515 ). Or are there any other problems (if yes- please describe)?
When exporting to iCal you should make sure you export the whole period and all categories.
roze
Post by roze »
Primary problem - I wasn't able to do sync EPIM-> Google without garbled national characters viewtopic.php?f=1&t=13220&p=55515#p55515.
So, I looking other Czech users of EPIM. I want to discuss this problem also with them.
But this thread is about iCal...
my question here is about different count of exported items in CSV and iCal files.
Is it OK?
Yes, I know ->
It is difficult to comment until we see the database. You can send it to ma@essentialpim...
