ics question
Jon
Been thanked: 7 times
ics question
Post by Jon »
I have exported a list of tasks from ToDoList in ics format. I cannot import this file into the EPIM 5.5.7 to do list. The process always ends with a report that zero records have been added. The date range for the import is correct. However, this file seems to import correctly in the EPIM calendar module.
Why is this and what am I doing wrong?
Thank you.
Jon
Been thanked: 363 times
Re: ics question
Is "ToDoList" the name of the application? We need to see the ics you are trying to import.
Jon
Re: ics question
Post by Jon »
Max wrote:Is "ToDoList" the name of the application? We need to see the ics you are trying to import.
Yes, that is the name of the program. Where shall I email the ics? As I said, it imports to the calendar module, but fails wen trying to import to the ToDo module.
By the way, why do you not have the option to import/export CSV into/out of ToDo and Calendar?
Jon
Re: ics question
You can email it to ma@essentialpim...
CSV is not the standard for ToDO and Calendar, while iCal is.
Jon
Re: ics question
Post by Jon »
I just sent you the file.
Jon
Jon
Re: ics question
Post by Jon »
Hi Max:
Any advice or feedback?
Jon
Re: ics question
Since we are dealing with 3rd party software, not so fast. I received the .ics file and we will look into it when we have time. Most probably the problem is with wrong ics export from another application.
Re: ics question
According to standard, TO Do should start with
BEGIN:VTODO
while Calendar events should start with:
BEGIN:VEVENT
In your ics file all events start with
BEGIN:VEVENT
Jon
Re: ics question
Post by Jon »
Max, thank you so much for this information. It works very well.
I'm still confused about why csv cannot be imported into the ToDo module. This would be valuable because we would have the ability to map to custom fields. You already provide a csv export option, so why not import too? By the way, I would also include csv import/export with the calendar module.
Thanks again.
Jon
