iCal import issues (german special characters)
180grad
Post by 180grad »
I am using EssentialPIM for already two years, because it is the best PIM solution for Windows and Android. :D
There is one little thing that is annoying. When I want to import an iCal Calender in German, I have troubles with the special german special characters. I am using EssentialPIM for Windows 5.57. See the attached screenshot.
Thank you very much for the help in advance.
Best wishes from Vienna,
Harald
Been thanked: 363 times
Re: iCal import issues (german special characters)
please post here or send me a PM with an iCal file so that I could check it on latest version of EPIM. Please also indicate which field exactly I should check.
thomas_s
Post by thomas_s »
the ics file is in UTF-8, try to convert it to Windows-1252 before importing (solved the problem here).
180grad
Post by 180grad »
Hello Max,
The calendar was imported from the link of my university website. I also tried to import the calendar file and got the same result.
This problem occured also at other calendar imports. See files attached.
oebb.ics
Austrian Railways
(737 Bytes) Downloaded 113 times
feiertage-oesterreich-2013-2020.ics
Austrian Holidays
(77.12 KiB) Downloaded 115 times
Thank you. Please also tell which field is wrong upon importing oebb.ics
I could not reproduce the problem. I have imported oebb.ics and the only task there was fine (I think so), see the screenshot (I am using latest 6.0 RC1 which is available in public now):
