icl calendar export/import from EPim to Thunderbird empty
julaf
Post by julaf »
I hope you will understand my english...
I exported my EPim calendar as .icl file, then imported it in Thunderbird.
It worked fine just once.
All further tests failed : export OK, import OK, but none of the events appear in Thunderbird. Only those of the first export/import.
Does anybody have an explanation ?
Thanks to all !
Been thanked: 363 times
Re: icl calendar export/import from EPim to Thunderbird empty
Can you attach a sample of such .ics file? We will check if it is a correct file.
julaf
Post by julaf »
Sorry Max,
I did not see you posted an answer... (I think I had no notification...)
So, here is a sample file I exported this morning, with Epim free 6.54
agd_epim_150824-1031.ics
(5.4 KiB) Downloaded 122 times
