Hi
I'm running latest and greatest version of essentialPIM Pro 7.5 and have problems when trying to subscribe to my iCloud calendar.
I've picked up the URL from my calendar on iCloud.com, and when I add it in the "Add new..." dialog box, it checks the URL, and returns the name of the calendar from iCloud.com..... so far so good.
But as soon as I hit "Apply" (it is supposed to fetch the calendar entries) it returns: "HTTP/1.1 404 Not Found" and nothings appear in the essentialPIM Calendar
Firewall is allowing the App full access.
/René
ePIM 7.5 iCal SUbscription for iCloud Calendar
- Has thanked: 1 time
- Been thanked: 1 time
Re: ePIM 7.5 iCal SUbscription for iCloud Calendar
Or am I doing this all wrong.... is there another way to Work with Apple calendars ?
please make sure you use "Public" setting:
https://www.dropbox.com/s/r9yblkvjlcm9p ... 2.png?dl=0
I just checked and it worked fine.
Hi
yep - mine is webcal://p15-calendars.icloud.com/published/2/Afs.....8Y9ulZOkFcWs, and when I'm in the "Add New.." dialog, and exits the URL text box, ePIM validates the URL correctly and even collects the name from iCloud.
But when I apply the subscription, and ePIM tries to syncronize, I get the "HTTP/1.1 404 Not Found"
/René
/René
Thank you. I can not reproduce the error. Can you maybe make a sample calendar where the problem would exist? Please send it to me via PM, we could then check.
Hi Again
Wauw - I see your point ! - When I make a new .epim file, the Cal subscription runs smooth
Apparently there is something in my old .epim DB file that is incompatable with iCal Sub.
I checked my DB... it has been opened in versions:
3.22, 3.23, 3.52, 3.53, 3.54, 3.7, 3.71, 3.72, 3.73, 3.74, 4.0, 4.01, 4.02, 4.21, 4.22, 4.23, 4.24, 7.24, 7.5, 7.51
but I can't give you a copy due to privacy reasons.
Thank you for the response, I'll find a way to export/import all my data fra Old to new DB.
Best Regards
René
Best Regards
René
