Total hours !
sirjeff
Total hours !
Post by sirjeff »
I would like to be able to total hours by week and by month or even by a date inerval. Can this be done or added ?
Been thanked: 363 times
Re: Total hours !
Currently there is no such function. But where do you want it to be shown? An example would be appreciated.
sirjeff
Re: Total hours !
Post by sirjeff »
The gridbox shows all records with the total hours per day per event sorted in chronological order. If there was a filter that was able to total the hours on a subtotal band per same type of event (either by descirption, category etc ...) and then the final footer band with the grand total for the date interval chosen.
Re: Total hours !
OK, thank you.
