iCal export: No RFC2445 specification?
Essenz
Post by Essenz »
Hi Max,
I cannot import the iCal in Windows Calendar (Windows Vista), which I exported in EssentialPIM .
Vista tells me: Not a valid iCal file ["Unzulässiges Dateiformat. Es werden nur iCalender-Dateien unterstützt, die der RFC2445 Spezifikation entsprechen."]
What can I do? I want to synchronize my EssentialPIM calendar with my s40 Nokia mobile phone and want to use the windows calendar for that purpose.
Essenz
Been thanked: 363 times
Re: iCal export: No RFC2445 specification?
What version are you exporting with?
Try to export just a couple of events, will it work?
Essenz
Post by Essenz »
EssentialPIM Pro 3.12
With just a couple of events it works!
Essenz
Post by Essenz »
It worked two or three times, but it does'nt work any longer ...
Windows calendar does not like some particular item that you are trying to import. Can you please send me an example of ical file that does NOT import? To ma@essential..if possible.
Essenz
Post by Essenz »
At the moment it works, even with many entries.
But thank you for the offer. I will send you the next ical file which does not work!
